E
Eldritch
Hi, I am new to home recording and since I am considering buying a mixer to use it for recording piano and voice via microphones, I have some doubts about choosing between two mixers and also the way that the mixer should be connected to my PC in order to record audio using Cubase. I am inclined to buy the KORG ZeroMixer4, but since it only connects to PC via firewire, and I don't have the port on my PC, I wanted to ask if by connecting it to my sound card, a Roland Quad Capture, using one of the mixer's outputs, and then recording in Cubase through the sound card, I would lose recording quality compared to directly connecting the mixer to the PC. Also, I've seen that there are firewire to USB adapters, but I'm not sure whether they would work in this case. Could you advise about this too? As an alternative, I'm considering the BEHRINGER DDM4000 as a mixer, which can be connected to the PC via a MIDI - USB audio interface. Do you think that it would be better, in terms of recorded sound quality, to adopt this latter solution?
Thank you for your help.
