mixdown?
  • Thread starter Thread starter drumboi
D
drumboi
if you were tracking using an analog mixer going into a 2-input soundcard on a computer, how would you mix down after tracking all the instruments?
Usually you would mixdown in your tracking software. What software are you using for tracking?
If you're recording all the instruemtns all at once, then you can't mixdown, as you've already mixed them down to stereo using your mixer. If you're tracking each instrument separately, then that's not a problem. Could you clarify exactly what you're doing?
i'm using n-track for tracking.
I haven't used n-tracks so I don't know the exact steps to mixdown but as long as you don't need to run ther mix through any external hardware like an eq or compressor you should be able to just select a mixdown function in the software and it will create a finished .wav or .mp3 file.
rax2112
Replies
9
Views
328
E
TieDyedDevil
Replies
0
Views
240
TieDyedDevil
TieDyedDevil
D
Replies
4
Views
281
PitchTempoAndriy
P
