E
EleosFever
Ok, I'm trying to make a cover of a song and my final mix sounds dry..
What effects can i add to make it sounds more "wet" ??
.....water ?
just kidding, try some reverb on the master bus. If it doesn't do the trick try opening a channel with verb and sending certain tracks to it as needed.
experament.
What does sounds dry mean exactly? When you mix in effects, dry/wet is used to distinguish between the original signal and the effect but what does sounds dry have to do with the type of effect?
your mom sounds dry
