I worked with 1 engineer who would mix with everything in the center before re-panning for stereo.Sorry for such a basic question but is it a good practice to mix in mono? I'm just rediscovering this after too many years. thanks.
That’s a good idea for balancing levels.I worked with 1 engineer who would mix with everything in the center before re-panning for stereo.
I've always found this to be confusing logic, and I've never understood it. If one gets the levels all hunky-dory in mono, aren't all those relationships are going to change as soon as one pans out ?That’s a good idea for balancing levels.
Back in the days when records used to come in mono and stereo, there were often distinctive differences between the stereo and mono mixes.I worked with 1 engineer who would mix with everything in the center before re-panning for stereo.
Not optimalI worked with 1 engineer who would mix with everything in the center before re-panning for stereo.
The vocal is generally half a db too loud in mono, but just right in stereo. And rhythm guitars can fall way back in mono. But a bump with EQ below 600hz (200-300hz works a lot) can make it present and punchy in mono without having it fall back too far because you can get the perceived balances closer to each other. (instruments sit better inside of each other)I've always found this to be confusing logic, and I've never understood it. If one gets the levels all hunky-dory in mono, aren't all those relationships are going to change as soon as one pans out ?
Something I like doing on my mixes recently, is, if the song supports it, having a section in mono then breaking out into stereo for some contrast.
Yes some people swear by it. But I only do it for like 30-40% of my mix. I'll flick backwards and forwards a bit near the end for checks. Mono compatibility is very important to me.Sorry for such a basic question but is it a good practice to mix in mono? I'm just rediscovering this after too many years. thanks.
I mix in stereo but I do listen to my mixes in mono out of sheer curiosity. The last time I listened to any mono machine must have been......1979.I mix in stereo but I do listen to my mixes in mono to check for phase cancellation, comb filtering or any other issues
No - but it might help if you learned it - but we are currently living in a Atmos world - mono mixes offer very little.Sorry for such a basic question but is it a good practice to mix in mono? I'm just rediscovering this after too many years. thanks.
