Mix for Master
  • Thread starter Thread starter starbuck26
It will depend on the bus structure of your DAW. For example in Pro tools TDM the bus operates at double the word length of the individual tracks to allow for additional headroom when summing tracks, so lowering levels here is absolutely fine. If OTOH the bus operates at the same bit depth as the tracks it would technically be better to reduce the level of the tracks.
The correct answer is to find out the details of how your DAW operates and work accordingly.
Doesn't help with the nosebleed though ...
I've been sifting through your reply and Glen's reply last night and this morning. Things are getting more complicated yet again.
So my DAW, a Zoom HD-16, records 44.1 khz at 16bit. I use that to track, and then move everything to Cubase LE, where I mix.
I assume that since Cubase handles a much higher bit depth that I am ok lowering fader level anywhere I please, either track by track or in the master fader.
Or do I not understand anything you're telling me? :confused:
Well, yes and no.
Having a larger bit depth in Cubase is an advantage, but the issue that you mentioned in the inital post more has to do with summing tracks.
Let's use an analogy to demonstrate. In place of audio let's use water and in place of bit depth let's use the concept of a bucket. Furthermore a bucket can be made of metal or rubber. When you reach the volume of a metal bucket, it will start to overflow, however a rubber bucket (like a ballon) will automatically resize itself when it is being filled up to a certain limit.
A fixed bit system is like the metal bucket, once you've used all of the bits it overflows and distorts. A rubber bucket (floating point system) will expand and contract based on how much it contains.
Ok, now with that in mind, imagine each track is a bucket of water, and all of this water gets poured into a drain (bus) and into another bucket that contains all of the water (master bucket). In some fixed bit systems (like Pro Tools TDM) the master bucket is made large enough to contain all of the water from all of the tracks even if they were filed to the brim. However it must pour this out to a smaller bucket (final bit depth) and as a result you may need to reduce the amount of water by taking some out intentionally. HOWEVER, no water was accidentally lost by overflowing, so life is good, the system knows exactly how much water was removed. Distortion will happen when the system thinks it knows how much water was removed but actually some of it was spilled all over the floor, or you didn't shake the bucket (dither) after removing the water (this is a whole other topic).
In the case of floating point the rubber buckets or balloons will stretch to accommodate the extra water to a certain point. In these systems the master bucket is usually the same size as the individual buckets, but due to stretching will not allow the water to spill if it is not near enough to popping the balloon.
The objective is to know how much water your master bucket can hold before overflowing or popping (clipping).
Ok, now I have a headache.
Just do what Glen said ...:)
Well, yes and no.
That actually cleared a lot up. I can't thank you enough for that analogy.
Now my question is... how do I found out more about my cubase buckets?
As for doing what Glen said... I know enough from all of his advice on this site that I should always just do what he says... but, unfortunately, in this specific case... I have no fucking clue what he's talking about in this specific case, but I do recognize that there is yet another gem of knowledge awaiting me. :D
The word dither scares me by the way. I've been reading a textbook on mixing audio... I actually felt portions of my brain shutting down while reading about bit depth conversions.
I don't want to overcomplicate things here, though. If either you or Glen can confirm that I can safely lower my track faders in cubase LE I will get back to mixing my Stevie Nicks cover in relative peace and stupidity... :D
While I appreciate the vote of confidence....GOOD LORD NO! :rolleyes: If you had seen my completely wrong initial answer I gave a couple of weeks ago about the operation of a mixer of the type I was sitting right in front of at the time, you'd know I make some boneheaded mistakes just like the next guy. Of course, I was sick as a dog at the time I gave that answer, but still...a boneheaded answer is a boneheaded answer.
Yes you can. Think of it this way; if you couldn't mess with your track levels, you couldn't use volume level automation - level automation is basically dynamically changing track volume levels on the fly. So sure, adjust the track levels. In fact, I recommend setting the levels so that you're getting the "right" levels out of your master bus with the master faders set to unity.
I'd try to explain more about what I was saying about gain structure, but I don't want to bruise your brain any further here. Let me just leave you with a bookmark: head over to IRN at www.independentrecording.net an click on the "Metering and Gain Structure" icon on the lower right to pull up an on-line interactive applet that's chock full of basic generic info on what the different meters along the line mean, how VU, DBFS, and RMS and other measurements actually mean and how relate to each other on a real and useful level, and some basic methods for setting levels all along your recording and mixing chain from mic to plug-in to get the most out of your gear and your signal. Play around with that applet at your leisure, take small bites and swallow between them, and you might just come out the end with no head injuries and an understanding of the common thread of levels around which all these widgets and doo-dads have actually been designed to work.
But for now, let me say this about track levels. When I sit down to start a mix, the initial set-up stages are usually a pretty quick 3-step process for me. This process is not the only way to skin the cat; others may take slightly different approaches, and that's fine. This is just what works for me. Maybe it'll help you out just a bit for starters, without having to go into a bunch of gain structure theory:
1.) I give the mix a faders-up listen. This means setting all track faders and master faders to unity gain (the 0 mark about 2/3 - 3/4 of the way up the fader. This tells me two things: first, how I want to initially adjust the track levels in step 2, and second, how good the tracking was and how much work I have ahead of me (the better a raw faders-up sounds, the better the tracking and the less work I have ahead in mixing.) I may or may not set initial panning at this point; usually I get the initial/basic panning scheme out of the way right then and there based upon what I hear.
2.) Based upon what I hear in the faders-up mix, I set initial volume levels for each track relative to one another, just getting them each roughly in the ball park for what I imagine in my head that I want the final mix to sound like. IMPORTANT here is that I never raise any of the track faders. I just reduce each one by the amount necessary to get the relative volume roughly in line with where it belongs in the mix with the other tracks.
The faders virtually *never* (well, maybe one in 20,000 times only) go above unity gain. At least one track - sometimes a couple - usually stays there at unity; especially if they are quieter-recorded tracks that need to be loud in the mix. Those are the ones with the highest gain setting, at unity. Others might be 2-3dB down, still others may be dropped more than that; it all depends upon how the tracks were recorded and how the mix plays out.
3.) Once I have those rough starting mix levels set up, I switch automation on for all tracks, setting the initial flat line level for each track somewhere around 3 or 4dB down from the top (maximum) level. This gets me ready to individually start actual track mixing for the final mix, using automation heavily (see the current thread in this forum on texture and automation) to do my mixing. The extra 3 or 4dB of headroom I give myself allows me to move the fader/volume level for that track up by up to that much at any point, should the overall track level be a bit low and I need some extra oomph here or there.
Then I start the track detailing in earnest. The EQing, compression, automations, etc.; usually submixing the rhythm section (bass & percussion) first, then the accompaniments, the finally the leads and main vocals, in that order (usually, but there are always exceptions.) If I need to make fine tuning adjustments to the individual fader and automation levels at this point, I do. But I almost never send a fader or automation level above unity gain. The only real exception to that is if the tracking is soooo poor and uneven, and one track is so anemic and low-level that it needs the above-unity boost just to be heard. But even in that case, I'll try to get a re-track first if possible.
Usually for me, assuming that I have fairly decently gain staged recordings with behaved recording levels, the final mix winds up coming right out in the sweet spot fairly naturally, without having to touch the master faders, just leaving them at unity. There are exceptions, sometimes, but it far more often than not just works out.
HTH,
G.
We all make mistakes. Big fucking deal. The most recent post of yours I had in my memory, Glen, was the one you wrote on the digital clipping on the RHCP album. No one really responded to it, likely because they were dumbfounded.
We are indeed NOT making pancakes.
The explanation of your gain staging basically put it all together. I had already been looking at independentrecording.net, and been studying the metering and gain staging charts. More useful than that, though, was the interactive eq chart. With my lack of experience it was a big help to have some sort of template to use when getting started.
So cheers, man. I meant what I said.
Thanks to everyone who gave me some insight into all this science...
a few people actually messaged me and said that this was a good question. So hopefully it's pointed a few of us in the right direction, and not just me.
And it's just in the "nick" of time. Stevie ain't getting any younger, and her nose is about to fall off... we better finish this album quick. :eek:
T
The problem with just lowering the master fader is that this lowers the output level and you could still be clipping the input of the master buss. Some DAW's and plugins allow you to monitor the input level.
