T
tomy
want to ask what's the method u'd like to use it when u want to mix down midi track to audio track?
Simman said:MIDI is not audio, it's control information (i.e, note, volicity, etc.). So MIDI track plays/controls a module ( drum brain, synth) and you record the audio from the respective module. Don't know what you record on but most likely the track will be recorded as a WAV file .
Laynestaley said:Nothing gets recorded except for the control information that 'triggers' the virtual instrument. That's why you have to export it as a wav-file and then import it again if you want to treat it like audio.
tomy said:want to ask what's the method u'd like to use it when u want to mix down midi track to audio track?
