Lorddiagram,
I have that card also. This card is NOT plug & play, so what you have to do is set the jummpers on the card to an open IRQ and Memmory Address and make sure none of your other cards do not try and take these resorcses. You may have to install all of your other devices first and work with their settings via the Device Manager (Control Panel). If you have to, you might also be able to go to your motherboard configuration setup and force things to work, but I would do that as a last resort. Once you are able free up the needed resorce, then you can set the jumppers on the card and set up your software. IF you still find that you are in need of Win 95 drivers, email me at Fishmed@aol.com.
Good Luck.
