Soulgolem
Member
Hello, I've been trying to figure out the audio recording portion of Cakewalk, slowly getting there. I recently hooked up my Yamaha P90 digital piano to use as a midi controller for programming some drums. It's midi outs are plugged to the ins of my LynxOne soundcard and vice versa.
Here is the problem, when I play a note, the midi message gets to Sonar, if recorded I can see the note in the piano roll. But no sound in the monitors. I select LynxOne midi in as the input and LynxOne midi out as the output.
If I change the output to the regular soundcard in my PC (soundMAX) I can hear the notes played coming out of the PC speakers. I don't have any soundbank for midi installed on the PC, I was hoping on trying to record drums with the cheap general midi sounds just to get a hold of it. But I can't seem to use my LynxOne for that application, and the only sound I hear with soundMAX soundcard are not coming from the monitors, thus, the mix.
I'm very new at this, so I hope someone can help me.
Thanks,
Francis.
Thanks,
Francis.
) drums sounds. Or, if you have Sonar 3, you can use the VSampler to play sound fonts.
