Midi Merge Recording and Playback
  • Thread starter Thread starter guttapercha
guttapercha
guttapercha
Hello,
I've been away from the forums a while - new baby, cross country move, new job.
Finally, I have recently had a chance to get into the basement and fire up the DAW. Anyway, when I lay down drum tracks, I like to layer different parts with the merge feature. For some reason, I can't see the first layers - only the most recent layer layed down. All the layers still play back. But....when I go to cut and paste, it only takes the layer that I can see.
I'm sure this is the easiest fix ever, but I can't seem to figure it out.
Thanks,
JD
on your transport controll bar there's a tab that says mix (midi) lft click it and then you should see 5 options try mix..
