C
Cazzbar
Throbbing Member
Hi, I have just purchased V3.3 of n-track.
I have set up two tracks, one to record the Audio from a keyboard and the other to record the Midi from the same keyboard at the same time. I am playing in time with n-track's metronome.
After recording you can see a clear timing difference in the two graphs for each track- the Midi graph is lagging behind the Audio graph. I was hoping the two graphs would line up.
The Audio recording is in time with the metronome, but the Midi is about a quarter of a second (250ms) behind the metronome.
I have to drag the Midi graph left to synchronise it with the Audio graph and the metronome.
Is there a way I can record to remove this lag from the Midi track?
Please note this isn't a problem with a MIDI lag during playback (I'm not using a software synth) and once I manually line up the two tracks they stay in time with each other on playback, it's a problem with the recording phase as you can quite clearly see after recording the MIDI has taken slightly longer to get into the system and record than the Audio.
Thanks for your time.
My system:
Processor: PIII 866Mhz
Memory: 256Meg
Sound card: Aardvark direct pro 24/96 (using ASIO drivers, built in MIDI interface)
Keyboard: Roland A90
Recording options: 16bit, 44.1Hz
My system:
Memory: 256Meg
