midi keyboard problems
  • Thread starter Thread starter 682
682
Member
I have a Nektar 49+. I am using Cube AI latest but this problem came up with Garageband too. I have a vst track open
for record and the sound out is a different sound than the selected one. Its one of the other tracks or a variation on it.
Today Cube recorded the correct vst sound in Halion but the speaker sound was another tracks synth sound and it would not change.
You have to change the VST engine to Helm and then go back to Halion and that might work or not.Do I have a reason to return the Nektar?? Cause I would like to and try the A49 without any DAW integration which I dont need.
You probably don't need to return the Nektar. You most likely have set, or are setting, some control changes along with your midi, and these are resulting you in hearing things you're not expecting.
