MIDI controler for drums
mapexvenus
I am a drummer and looking to for a good MIDI controller than I can use to lay down some solid grooves. I am looking for a pad controller than I can use with sticks and that has a very good response when it comes to playing ghost notes etc. I am trying out the Alesis Control pad (connected via USB) and that isn't working out too well. I am experiencing some latency and the pad response isn't too great.
This is my setup:
DAW hardware: Mac Mini Server (2011) - 8 GB RAM, i7 Quad Core processor
Software: Logic 9 with EZDrummer
Is there a better product than the Alesis Control Pad that I should use? I want to emphasize that I need to be able to play using sticks and an external kick trigger.
thanks in advance!
This is my setup:
thanks in advance!
Just wanted to add - would the SPD 30 be better than the Alesis Control pad? How about the Alesis Performance pad?
MIDI drumkits
Try a MIDI drumkit. If you want to use sticks, pads are not ideal. My friend has a Pyle-Pro PED02M, and he swears by it. He even put a mic on a real cymbal and integrated it into his plastic MIDI drumset. It's about as close as you can get to actually playing drums.
