hcaulfield
I am hoping that this is the right section to be posting these questions in. If not, I do apologize and please feel free to move the thread.
Any advice on the following questions would be very much appreciated:
Microphone:
1. When recording vocals, is it better to turn on the low cut switch during recording, or should it be kept off?
2. What's the best distance to stand from the microphone to get the best results?
3. (This is basically a 2nd part to question #2) When using an external microphone pre-amp, how do you determine your levels with your distance?
4. Should the -10db switch be turned on or off (given there is one on the microphone)
EQ:
1. When recording vocals, do you find it more comfortable to record with eq/compression on the monitor mix? Or is this considered a no go?
2. Is tracking vocals to an already mixed song (eq/compression on everything but the vocals) a bad idea?
I hope these questions aren't dumb. I am just trying to get a little more familiar with how to get better vocals at the source to save me time later on.
Thank you all!
Microphone:
EQ:
Thank you all!
