They don't. This is a myth repeated ad nauseum by people who have never accurately tested it. I have, and I posted the results here. Microphones respond to sound according to their polar pattern and frequency response, including proximity effect for a directional microphone, period. Transient behavior makes little difference for ambient noise, as the noise of concern is generally broadband and sustained.
Set up an experiment for yourself and see, people have been misleading themselves.
What is true is that since dynamics are very low sensitivity, people have a tendency to place them very close to the source, otherwise signal-to-electrical noise would be unacceptable for quieter sources. That will create a difference in signal-to-ambient noise as well. But if you put a condenser with the same polar pattern as a dynamic (ideally the polar patterns will be similar across the frequency spectrum) the same distance from a source, and control for frequency response, you will find that the ambient noise is almost exactly the same (unless such ambient noise is swamped by electrical noise in the case of the dynamic, which very quiet noises could be).
Link? I must have missed that post.
I look up to you very much and respect your knowledge a great deal, but I'd really like to see just how you measured the ambient levels vs. close source to determine the accuracy. How many sample sources did you try? I'm assuming it was a rather large pool you conducted the tests from since you're results are so defining.
Perhaps I'm wrong, but I'm afraid I'm going to have to respectfully disagree with you. To make such an assertion with 100% certainty for all microphones in all categories is a little far fetched when it isn't even true among mics that fall under the same category.
I've had a weird observation over the last 2 years regarding tube mics vs. solid state that made me wonder. So based on what you've just posted I decided to verify it for myself just for my own clarification.
To make sure I'm not just full of myself I just did a test with several microphones, level matched at the same distance, capsules side by side and in polarity, with a source for ambient sound that would be consistent for my test. A fountain, TV on in another room, plus the heater running in my room.
Both sets of mics have the exact same capsule in all of them: K47 copy. One set is solid state, the other tube. I have 3 identical mics in each category just to rule out it being a specific mic. I set the channels all at 0 and then matched the peak levels between channels to my voice and then panned them hard left (SS mics) and hard right (tube mics). The results aren't even subtle. There is
clearly more ambient sound being picked in all the tube mics vs. solid state in all the tests.
Next I tried mics that had K67, SS vs. tube. Same result.
I have a theory as to why, and I think it has to do with how the circuits work. This usually happens when something either loads the capsule, causing physical electrostatic damping, or part of the circuit is starved. This can happen when tubes mics are "grid starved" by the wrong value grid resistor.
In any case, the frequency response, polarity and patterns are all the same, yet my results do not match your accurate tests. If I can have such varying difference among mics in the same category, how is it you achieved such concrete evidence in your tests?
Care to elucidate?
