Micing Guitar Amp
  • Thread starter Thread starter Rockthatcross
R
Rockthatcross
What's the best type of Amp to use? I've heard tube amps are, but I've got a 30 watt Marshall and I'm micing it with a SM48. It just sounds soo fuzzy and non professional. I have it plugged into a tascam us-122 and software is cubase SE.
What's the best style of music to play? :confused:
Seriously, though, do you like the sound of the amp live? If so, then turn the gain down a lot and then record. Have you tried different mic positions?
And if by professional you mean similar to an album, then forget it with your current set-up. Your amp probably has a 10" speaker (most 30w SS amps do), and that alone will make it sound a lot different than 4x12 cab, which is what is often used in the studio to record heavy guitar (I assume you want to record heavy guitar, but I suppose I shouldn't assume anything). The 48 is meant to be used for live vocals, not guitar amps. That will also make it sound different. And the final thing that separates a typical home recordist from a studio is the room. From then on, all you need is talent!
Welcome to the board!
thank you, i like sorta pop punkish sound. I have a fender amp with 2 12 inch speakers too. but when u have multiple do u place the mic in between the two or just on one?
When I mic, I just place it on one speaker. If I want a good, clean sound, I might use 2 mic's, each on a different speaker, but that is different. You will need to mess around a bit, but most of the time, for a distorted sound, near the cone. Slightly out to the side, maybe, but just try multiple places.
Use the Fender with 2x12s. If you don't like the sound of the distortion on it (many don't, I personally don't think it's too bad) then put a pedal in front of it.
I know this sounds silly, but the better you make the amp sound by tweaking the settings, the better it will sound recorded. Also, purchasing an sm57 will help a lot with the tone of the guitar, if you buy it new, it even comes with a diagram of suggested miking techniques for speakers and such.
