At the risk of getting the same grief as on the microphone forum, I will say this. The best advice I got in recording drums came from Simon Phillips. At the risk of being bashed as a name dropper, he's a good friend of mine and I broke down and asked him what to do one day. His advice was:
1. Make sure the kit is tuned well. If you don't know how, search the internet or find someone who knows how to tune a kit. This is the MOST critical.
2. Throw up a pair of decent condenser mics as overheads. Get a good kick mic, like a shure Beta 52. (If you don't have alot of money a Superlux FK2 can be found on ebay for about $35.00. I use it and like the results. This is NOT Simon's suggestion! It's mine.) If you have a hole in the front head, put the mic just inside the head, pointed at the beater. record the kit. It should sound good with very little EQ and 3 mics. If it sounds dead or off, the room may be too small and too dead. You may need to adjust the room's acoustic treatments. He uses a very big room with ambient mics on the other side. reflective is better than dead.
3. If it sounds good, add mics like an sm-57 to each drum until it sounds nice and full without too much bass. The snare is most important if you don't have alot of tracks. And yes, going to a mixer before the recording device is OK. Don't think that the overheads are just for cymbals. It gets the whole kit. Also low end helps the cymbals, not just the high end. It'll pick up the toms just fine. If the kick needs more lows because of a poor mic you can find a pretty good 8-10" woofer and attach an XLR cable to the leads, making sure the speakers negative is the XLRs positive and opposite for the negative. Screw the XLR sheild to the speakers frame. Mount it about 1-2" from the front head. (Kind of like
a Yamaha subkick)
4. If you can afford to track each drum separately, add effects on mix-down. If not, add some to the overheads to give a little ambience. Be very careful. Once you've printed the track, their's no going back.
It may sound too full solo, but once you add the other instruments the highs are what end up standing out. You should need very little EQ. As a rule, too much EQ is destructive. Get the sound right coming in, starting with the right mics. Good preamps are a good idea too. Simon told me a $10,000 mic won't help the sound if you have bad preamps.
I Hope this helps. It's made all the difference in my recordings.
