just curious... what kind of condensor do you have....
These are all fantastic suggestions, but are really dependant on having that one mic shine spectacularly.
If you're interested in minimalistic jazz recording, check out anything on the Chesky label... they record everything with just one or two room mics, and have put out great recordings by Phill Woods, Tom Harrell and a load of other great cats.
If you're holy grail mic is just that, I kind of agree with scrubucket, you can get decent sounds like this in jazz...
I also liket the 6 up 6 out suggestion... a jazz set is very different than rock or pop, and the way a great drummer uses the set is in a word, dynamic. The 1.5 sticks above the center of the snare is a little unnerving to me, by my measurements, that's not going to give you a whole lot of space between the magic condensor and the equally magic cymbals, and the overall tone of the set might get lost.
One other suggestion you can try, depending on the guy's setup and one mic, is eye level, or just below the ride, 3 - 4 feet out directed towards the snare through the crack between the tom hardware and the hi-hat. (wish I could draw a picture)
The only potential benefit is if you're micing everyone else seperately, this will give you slightly less bleed, as it's closer to the set than the 6 up 6 out, although you may have to compensate for a little boominess in the kick and toms.
btw, how are you micing everyone else... are these three mics and 2 inputs for the whole band, or is this what you had left for the drums?
Good luck
Rich
Radium Reactor
