R
rol123
2 mics-both Cardoid condensers, both list between 1000 to 1500; 2 very different manufacturers--both are large diaphragm capsules -both center terminated.
Samples are in mp3 format, recorded 24 bit, 41k both are going into a Scarlett 2i4 audio interface
Levels are matched as best I could--no pop filter, no compression, (no soundproofing)--Mic cables were identical length, same manufacturer and type
Some handling noise is present due to the fact that this was a 'quick and dirty' shootout..mics were handheld during this quick shootout.
Both mics were spaced an inch apart; both diaphragms were at the same level to each other. I spoke in-between both mics.
You be the judge.
I am thinking of selling one of the mics..had to re-check to verify there was no mix-up after recording based on what my ears were telling me. Please listen carefully.
I will reveal the results after a few comments
again, let me know which mic sounds best with my voice
thanks for your opinions
You be the judge.
