Mic setup for drum kit with 5 cymbals ?
  • Thread starter Thread starter Alchemist3k
A
Alchemist3k
Hi folks, it's been a while, but I must seek your excellent advices once again. Until now I've been recording as a solo artist, however, I agreed to help a local band make some demos of some of their new tracks. This shouldn't be a problem apart from the drums.
The drummer has agreed to use an electric kit in the main for all sounds bar the cymabls. I thought things would be straight-forward until he mentioned that he uses 5 cymbals and wishes them all to feature in the songs. I had previously thought it would be a matter of stereo overheads and one on the high-hat but now I'm not sure how many mikes I should use and in what configuration.
I'll post a picture of it here shortly.
I'd use an X-Y overhead setup. that should be fine. At the most I may put spot mics on the ride and hat just in case but I'd bet stereo overheads would be plenty.
Well, that sounds sensible. Last time the band made demos of some tracks at a local university with a full ProControl 24 setup. The initial mix was very poor because it was done in a hurry. My setup is nowhere near as expensive so I hope I can do their music justice.
Anyhow, the drummer complained last time that a stereo overhead setup was used and he couldn't hear some cymbals as a result in the mix. Also, he wasn't happy that the ride got panned all the way left as a result. Maybe spot mics might be needed then. How should they be positioned?
You can hear the band here:
www.mangara.co.uk
Here's the pic:
Unless they are doing tribal medicine music where there are special cymbals for each incantation I would tell the drummer to get over himself. It's just some fucking cymbals.
You can always compress the overheads to balance everything out.
ROFL:D
www.mangara.co.uk
I track with a stereo pair of Rode NT3s either in X/Y config. or as a spaced pair...this setup is more than adequate in my book for picking up the cymbals (even hi-hat) - and I'm a drummer!
If he doesn't like the panning of the ride....just don't pan hard L/R!! does he understand that a stereo drum recording represents a stereo image of the drums?? maybe he should move his ride to the center of his kit????;)
