H
HB1978
How important is mic preamps. If you have a good mic let's say the Sterling Audio ST66 is the mic pre still necessary?
A not so great preamp will never show what a good mic is able to do. It'll only be as good as it's weakest link.A good mic isn't going to be any good through a shitty preamp.A not so great preamp will never show what a good mic is able to do. It'll only be as good as it's weakest link.
I like those Aphex units. No frills; just good, clean gain. Paired with the Sterling 66, I imagine that sounds pretty nice.
What's the medium? Vocals? Acoustic instrumentation? Both?
Mic preamps are fairly important if you have a decent microphone.How important is mic preamps. If you have a good mic let's say the Sterling Audio ST66 is the mic pre still necessary?
But there is also another factor to consider; how well the mic and preamp match up. If you have a mic that requires (just for example) an amp with 65dB of clean gain in order to get the signal up to line level and you have a cheap preamp that's only rated for a clean 50dB of gain, you're going to have trouble getting a full signal.
Similarly, but arguably not quite as crucial, is that typically you want to look for a preamp that has a rated input impedance of somewhere in the 5-10x grater value than the rated impedance of the microphone in order to get decent performance matching. This i usually not a problem, but some cheaper preamps are designed at much lower impedances than that.
Not that the proper amount of preamp gain and impedance matching will guarantee a quality sound, but it can be hard to get that sound without them.
G.
My mic is connected to a Pro Tools MBox 2. With all that said I still do have turn up the gain on the MBox to almost the max to get a fuller signal. But I will try using the pre in the signal chain.
Wait a second... you have a $600 Aphex pre and you've been bypassing it and going directly to the MBox?![]()
Correct. The preamp provides the gain to the mic. The MBox is also capable of this (although on a much more limited basis as you have found). Assuming you're using the standard MBox 2, the max gain is only +50dB. I think the Aphex's have more like +65dB.
Ideally, run the mic to the Aphex, then the Aphex out to the MBox's line in. If you've got the digital version of the Aphex, then you can run S/PDIF directly to the MBox's digital input.
That's it's function, it's job in life, yes. The idea to to boost the voltage from the microphones, which by design are low-voltage devices, up to the kind of "line-level' voltages for which all devices in the rest of the analog signal chain are designed to operate.Does the pre only give gain? Is that the only purpose of the pre or is it suppose to make the vocals clearer? Forgive me for the stupid question.![]()
