It is not possible to answer your question from where I'm sitting. There are so many cumulative factors that can cause vocals to suck. The most common ones are:
1. The singer sucks (today).
2. The engineer is inexperienced or incompetent. (the first one can be fixed)
3. The song sucks.
4. The room sucks.
5. The singer is singing through the wrong mic for them.
6. The mic sucks.
After you have dealt with #'s 1-6, you have finally gotten to your question- what to do if ...
7. The singer is singing through the wrong preamp for them.
or the ever popular...
8. The preamp sucks.
#1 is first, because if it is true, fixing all of the rest of that stuff doesn't help. Only you know if you suck. If you're an American Idol reject, you suck, but you *don't* know it.
#2 is what it is. There are many more inexperienced people than there are incompetent people. Keep trying, you'll get better. This, of course, applies to #1 also. Many singers who suck can get better. Very few suck terminally, but it's a question of attitude. Some people *refuse* to learn.
#3 is mostly a matter of opinion. Watching a great performer sing a song that sucks is very interesting. Ray Charles probably could have put on a show singing the weather report.
#4 - ding ding ding! You have selected the most common problem that people will not fix! They will spend hundreds, or thousands on gear, to use in a room that sucks, and they complain about the gear. This is 10 times more likely to be your problem than the preamp. It is easier to find a room that does not suck to begin with than to fix up one that does.
#5 This is a common problem. Don't you hate it when you suck through a mic that makes another singer sound like a god? What will open your eyes (and ears) is when you switch to a different mic, and the situation is reversed! Maybe a SP B3 isn't the right mic for you. In order to find out, you have to deal with #'s 1-4 above, and *then* sing through a bunch of mics.
#6 Could happen, but almost every vocal mic on Earth sounds good on
somebody.
#7 Preamps are less finicky than mics, but some mic/pre combinations aren't so good, and some of them are bad (or good) on certain singers. Preamps, like mics, are like shoes. They either fit, or they don't.
#8 I doubt it. The preamps in the Mbox are average. Not stunning, but they don't suck, unless they are compared to big bucks badass pres, which is not what you appear to be in the market for.
So my best answer is another good quality cheap preamp will probably not be any better than what you have now, but- it will be different, and it might or might not work better for you than the mic/pre combination you are using now, which you think you don't care for. Or- you haven't dealt with #'s 1-7 above. In a nutshell, that's what I've learned about tracking vocals. The rest is all in the realm of psychology.-Richie
