R
Ranman
I have a Tascam 788. I noticed when I played the 1st CD I made that the volume was way down and had to turn the CD player way up to hear the track on the CD. So on the advice of someone on this forum I bought a Behringer ultragain pro-8 (ada8000) to boost my input levels. I get a bad hissing noise when I hook it up. Not a tape hiss, but the kind of hiss you get when you are flipping channels on the tv and come across a station that is off the air. Here is how I did it. I plug the mic directly in to the front of the ada8000. I then go out of that into channel one of the recorder. I have to use an adaptor because the input on the 788 is 1/4 inch. When I bypass the ada8000 it works fine. When I go through the ada8000 I get the hiss. Have I got it hooked up wrong? It is pretty simple and I don't think I am that stupid but maybe I am missing something. I have tried different channels on the ada 8000 and different cables. Same result. Any help with this would be appreciated.
