Ghost Lemon
Hi All,
I just received a used AT 2035 condenser mic off of Reverb for a demo that I want to record. The mic will be run through a Tascam DP-03 portastudio. The Tascam provides 48 v phantom power, which I have activated.
The issue is that, when using the mic, I am unable to monitor anything through my headphones during standby or recording, except a fairly substantial humming sound (even with the headphone volume cranked). The level meters seem to respond when I speak into the mic, but since I can't monitor anything, I'm not sure what the meters are responding to. Also, I purchased a brand new mic cable, so that is unlikely to be the issue. Also, I set the pad and the high pass filter on the mic to off.
When I switch to monitoring the unit's internal mics, I can hear them perfectly well, and the hum goes away. I recorded a few seconds of material, and I could hear my voice on playback, but it was very faint, even though I had set the trim quite high. I also switched inputs to see whether that was the problem, but that didn't make a difference.
So the question is whether I am missing something, or if the mic itself is likely defective. (The seller assured me that it worked but that he hadn' used it in a while). Unfortunately, I don't have anything else to plug the mic into in order to test it, nor do I have another mic to test the Tascam's ability to play nice with external mics.
Thanks!
Michael
Thanks!
Michael
