P
paresh
Member
Hi - My recording keeps beginning before the metronome count - in finishes. Cakewalk tech support says to: reinstall drivers, reinstall GT Pro, clean the registry...
That's a lot of hassle when I don't know if it's just a standard answer & may not even help. In fact they've given me that same reply before for a different question. Any advice? Thanks!!
) to play metronome. However, you cannot use DXi unless you sequence some pattern to trigger MIDI notes that acts as metronome. If that's the way you play metronome, there could be a latency problem with your DXi which causing slight delay betwen actual timing and metronome hit. Try using the PC speaker beep just to know if it's right.
