Actually, that's exactly what you were saying without actually saying it. That's what a sceptic does, they habitually doubt. If you doubt what someone has said, you are saying you do not believe them. If you do not believe they are being truthful.......
^^^^^^^^^^This, in spades.
Personally, I've found this to be a fantastic thread. Sure, sometimes, the science has gone over my head, but it's all been helpful. There's a big difference in saying "I track at low levels" and "Tracking at high levels will guarantee your sound will be lousy". One does not inevitably follow the other. As with many things, I find that there are paradoxes afoot in making and recording music.
On my DAW, I've noticed time and again that if one records the sound continuously into the clip zone, it sounds utterly awful. It's worse than nails down a blackboard. But if on the odd occasion, the sound peaks for a split second into the clip zone, you can't hear any of that digital clipping sound. In fact, you can't tell anything untoward has happened.
@Offcentre;
You've asked a couple of times why, if you record at high or low levels and find acceptable results either way, keep hammering home the point that you don't have to record at low levels because they are not intrinsically better. I thought the answer to that would be obvious. If the accepted wisdom
is that it does make a difference to 'go low' because higher levels are worse, then if you know that's not true, you perpetuate something knowing it's not true. Some people can live with that. Some can't. When a child cuts or grazes themselves, they automatically believe a plaster makes it better. It doesn't. I've always made the point of telling them that. Go wash it with water and let it get air so a scab can form. It'll do more for you than any plaster unless you're involved in some activity that risks pouring dirt into the cut/graze. But for decades the stock response to a cut or graze is to put a plaster on it. No one tells the child that it actually keeps the cut moist and hinders drying and scabbing. Usually, the child stops squawking. And the falsehood is perpetuated.
As for threads going off in unforeseen directions, you, I and no one else has any control over that - and that's a good thing. I've learned more from this intense debate than if someone had directly 'answered' your original question by pointing you to a painless link. Besides which, although you asked for no arguing {which no one can guarantee}, you asked for advice because you felt your gain staging through plug ins was wrong. That alone was opening the lid on a Pandora's box, which I would argue was a pretty healthy one.
