J
jonnyc
can you get an el84 powersection amp to generate a modern metal tone.
chrisharris said:No, I can't.
jonnyc said:Yeah but you suck. This is a matter of life or death you bastard. Go strum your variax and leave me alone.![]()
Funniest thing said todaychrisharris said:No, I can't.
watermelon said:Funniest thing said today
But I bet it's also making you all sweatyjonnyc said:Doesn't make me laugh nearly as hard as your avatar does.
watermelon said:But I bet it's also making you all sweaty
This happen in the mornings? I told you we should have waited til I could find a condomjonnyc said:Yeah, that happens when i get sick to my stomach.
na this was...watermelon said:Funniest thing said today
I'm about as metal as plastic.
jonnyc said:Ok though seriously. I'm having a debate with someone and need to know if an el84 based tube amp is capable of achieving a fullout metal tone. I've been informed that the preamp section is much more important. I'd like to if this is true or if it's some kind of combonation. All I know is every crunchy british style amp seems to run on el84 tube while more "metal" type amps I've seen run 6l6's.
I think you can achieve that sound just by "scooping" the mids when you eq. The tube you have makes some difference, but it's mostly knowing where to cut the eq....jonnyc said:Ok though seriously. I'm having a debate with someone and need to know if an el84 based tube amp is capable of achieving a fullout metal tone. I've been informed that the preamp section is much more important. I'd like to if this is true or if it's some kind of combonation. All I know is every crunchy british style amp seems to run on el84 tube while more "metal" type amps I've seen run 6l6's.
jonnyc said:Who's the fucking pussy that neg rep'd me and couldn't even sign his name. You affraid or something, little fucking bitch. Go crawl back in your little hole and try to figure out how to make your Marshall mg15 combo sound like the latest nicklecrap cd.
