ido1957
9K Gold Member
Work is brutal right now so I'm trying to catch up on a few listens and some mixing practice this morning (up at 4:30 am as my body clock is set for those ridiculous conference calls with India at 6 am everyday. Enough complaining...
Started from scratch and remixed this with all the comments on mind from the last time.
Specifically:
Took the lead guitar out of center completely and did a stereo delay across the spectrum. Lots of tweaking there. This now leaves the vocals uncluttered by the lead lines.
Panned all the rhythm guitars all the way L/R - again to fill the sides but away from center.
Kept the eq cut in the vocals - it's around 3.3K and just takes the edge off the vocals.
Tweaked the bass down a hair as once the center was opened up it came right out. I can still hear that growl that I like at this point.
Drums are same as last mix, which was ok as far as that went, I have a focus on snare being always apparent even in the busy parts.
The lead vocal came down a db or so as again once it had room to be heard, it needed it. Right now I find the vocals are consistent in level throughout with no covering by anything.
Accent on the chorus as before with that stereo crunch guitar part but dropped it so it doesn't jump out anymore, just punches up the chorus a bit.
The volume increase after the mix was skipped (in Sound Forge) but I did trim the ends as usual. The volume can be maxed on my WMP and it hits a nice level at max output.
So....I'm hoping this is done now, let me know what you think.
Edit - a few tweaks to the mix after listening on a few other systems:
Adjusted the delay/reverb on the lead guitar
Cut more in the 4k region on vocals
Took a db off the rhythm volume
Specifically:
