The Motherboard Is Extracted...
Well, that was literally one of the most hair-raising audio equipment repair related activities I've ever had to do.
I present to you, the MCI JH-416 motherboard:
It was hair-raising because I had NO idea the assembly was as heavy as it is. I mean, I knew the transformers would have some heft to them, but I guess I just didn't consider the cumulative weight of all 72 of them. I'll have to get a scale out to the shop but I estimate the motherboard assembly weighs around 80lbs.
The motherboard is actually two separate boards (which is one of the issues with these consoles as the trace links between the two boards eventually fail) mounted to a wood frame which is all screwed to the metal pan of the mixer frame. Even though the PCBs are mounted to that wood frame, with the mass of the assembly and the length it is floppy. I had to be very careful how I held it; where I grasped and the orientation I maintained to maximize the sheer strength of the panels.
The PCBs are made of glass-fiber type material which is good. I literally don't think it would have been possible to extract the assembly from the frame without serious damage to the PCBs if they were the phenolic type.
Why remove the motherboard assembly?
- Cleaning of the motherboard assembly AND the mixer frame
- Repair/upgrade of the board-to-board trace links
- Repair of the mixer frame
- Reversion of a number of janky mods/work-arounds that have been added during its life
- Properly address the root cause of the "work-arounds
- Solder up hundreds of feet of new wiring harness
Here's the empty mixer frame before I removed the motherboard assembly:
And here it is after the motherboard assembly was removed:
Where'd all the modules go? I rigged up a simple hanger board...makes it easy to get to the modules onesy-twosey as I'm doing a lot of research work related to identifying mods that have been done, repairs that need to be executed, selection of components for recapping, and development of a discrete opamp.
They are there behind the white sheet:
Also, just had to satiate my curiosity about one of the VU meters...these are Dixson meters, same as is found on all the Ampex AG-440/MM-1000 electronics, but these have "MCI" screened on them. Rare. A couple of the meters have busted glass, and one of them the needle was stuck midway. I was worried it was toast but hoped it was just broken glass binding the needle, so I took it apart to too see.
Love the look of the meter bridge:
Here is the meter of question:
And the happy result...meter is okay. I have some glass that I cut for another project years ago so at some point I'll get the meter cleaned up and install the new glass.
