Mbox - Protools LE: phase problem ?
  • Thread starter Thread starter Anje
A
Anje
I have had a Mbox I use with Protools LE for a few weeks now, and I am about to go deeper into 2 mics recording.
I haven't found a simple way/switch to invert the phase of one of the mic to avoid phase issues recording with 2 mics, have I missed something ?
Check the Audiosuite plugins. There should be one called "Invert". Highlight the audio region you want inverted and select "process".
Yes as well as the "Digi" eq's have a phase reverse button.
Having said that, and at the risk of saying the obvious, in all but a few situations (micing a guitar cab front and back, snare top and bottom) you shouldn't expect phase issues.
thanks a lot
yes I'll try to record an AC30 front and back, so it should be usefull :)
btw, any advice about mic placement for that kind of micing ?
Naw...no way to give you any valid advice as to mic placement in these situations...I'm not there to "hear" anything including what type of material your doing.
I would however suggest patience, placement, experimentation and your great ear. That'll be a good start.
JH
