R
		radiorickm
master your own
First off, let me say that i totally admire massisive master and blue bear sound for the advise they givel they are a truly wonderful asset. After the years they have spent working in studios they are full of good advise we will probably never come close to tapping fully.
However, I totally understand your point in wanting to master your own song. After all, thats why we do this and lets face it, i am not trying to compete with columbia records with my stuff. So here is my $0.02 worth.
I do my stuff the SIB route, not in the computer. I am assuming that your sound card has only a stereo out since you say you are going into CH8. I am hoping you are going into 8/9 but anyway. Also, because i am a SIB guy, i hope your soundcard can play and record at the same time...i think it shlould.
You also say you want to master "a track". i am hoping there are a bunch of tracks already mixed, and not everything from the 1604 dumped onto ONE track(or a stereo track).
Here is how i would set this up. For right now, you already have the insturments recorded into the computer, so lets unplug everything and start over.
Basically Your NEW source of sound becomes the stereo output of the sound card. You should have everything MIXED in the computer. SO you can send the MIX from the soundcard into the 31 band EQ. From the EQ out, go to the compressor limiter. From the Compressor, go to the 1604 on a STEREO channel (or two mono channels hard panned).
Your can listen to the effects (of the EQ and compress) on the 1604 thru the monitor sends. YOu would ffeed the processed signal from the RCA JACKS OUT on the 1604 to the STEREO LINE IN on the computer once it is where you want it.
After you have played the track back, about a thousand times and tweaked the 31 band eq, and tweaked the compressor limiter setting, you would record the track onto an NEW stereo track, or stereo wave file.
that processed track could then be sent to the CD Burner
is this the ideal set up? nope. but, it should give you a run at doing what you are trying to do.
