crosstudio
when mastering an EP wherein you have 5 songs of varying tempo and attitude how best to set the volumes such that the tracks run well together?
what i have been doing is multiband-compressing and maximizing the individual stereo mixed tracks as necessary, then using the volume faders to adjust the relative volume between songs.
since we are all so concerned with slamming the meters from stem to stern for every track how do we get the volumes of the individual stereo mix tracks to lay together for a cohesive unit?
so i started thinking.
maybe i should take the 5 songs (with no eq, compression or peak limiting) and just play with the volume levels until i get them to gel and take note of the varying volume levels.
then
set all of the tracks back to 0db, start adding on the multiband compression and peak limiting to get the songs blazingly loud like everyone else in the industry, then adjust the gain on the peak limiting such that the volume level deltas between the individual songs are preserved.
for instance, lets say track 1's volume was set to 0db while track 2 was set to -2db when i was just trying to get the relative volumes correct.
then
once i get the loudness maximized just right for each track, i would back off of the gain on the maximizer by -2db for track 2 to make sure that the relative loudness between the 2 tracks is preserved.
is it possible to love and hate something at the same time? there's no such thing as bad sex, but bad music is limitless.
then
then
