Light
gbdweller said:To put it as simply as possible, the braces are carved to the smallest dimension possible, while the luthier periodically taps the top listening for the effect on the 'tap tone' as the brace dimension changes, all the while attempting to maintain a structurally sound top.
Well, that's the way some guys do it. But to be frank, the guys who tap their tops do it because they are trying to get a more consistent sound from guitar to guitar, and they are unsuccessful. There are a lot of hand builders who do NOT tap tune their tops, and they make guitars which are every bit as good as those who don't. Tap tuning is an attempt to bring some degree of science into an area which is really not quantifiable. It may work on arched top instruments (arch top guitars, violin family, etc.), but on flat tops it is really a waste of time.
The biggest problem I see with it (which may be unrelated, but which seems to be the case with most "tap tuning" guys) is that they build their tops WAY too light. You want it to be fairly light, yes, but if you go too far you lose a lot of bottom end, and all of your dynamic range. If a guitar is too light, then as soon as you start really laying into it, it completely falls apart. The guitar starts to sound really farty and nasty. They also become much more prone to structural damage and decay, which is to say you will need your neck reset much sooner than with a guitar which is made with a slightly heavier top. It is something which will vary a lot from guitar to guitar, but there is no question that a guitar which is too light will lack the range of a guitar which is built right.
As to why guitars don't have sound post, the answer is very easy:
Because they don't.
That's just not the way they were designed when they were getting designed. These days, we are so used to the sound of certain guitars that if someone does something drastically different, it doesn't sound right (take as an example the collapse of C. Fox Guitars ... He tried to make something which didn't have a X brace, and the company didn't even last two years).
Now, if you want me to spin some bullshit theory as to WHY guitars where designed without sound posts, think about how you hold the violin family instruments. In each case, the back of the instrument does not have any major contact with the player. It is left free to vibrate, and so it makes a contribution to the sound. Now, think about how you hold a guitar. The back of the guitar is pressed right up against the body. All that would happen with a sound post is that the vibration would get sucked right up into your body, and it would get robbed from the top, making for a quieter instrument.
But the real answer is because that's the way people are used to guitars sounding.
Light
"Cowards can never be moral."
M.K. Gandhi
