leddy
Been on the hunt for a good cassette deck for some transfers. Maybe a good portable for some field recording fun too. I have a broken Sony WMD-6C waiting for attention, but I came across a PMD430 cheap. Sounded bad when I got it home, but a quick azimuth adjustment fixed that. Wow/flutter is unacceptable with batteries, but the speed sounds spot-on plugged in.
I took the time to set the bias (it's a 3-head deck) properly and make some recordings. Test tones show it mostly flat up to about 15khz (probably better if I had any metal tape laying around). With DBX engaged and levels kept polite, it sounds gorgeous.
Won't be able to use it as a field recorder with the battery thing, but I'm happy to have found such a quality deck. Highly recommended if you come across one.
