Lt. Bob
Spread the Daf!
I use whichever cable that my hand grabs in my big bag 'o' cables.
I don't buy into a lot of the cable hype either (all I care is they don't get twisted up on me!), but a guitar isn't an exercise in electrical engineering purity, it's a real-world musical instrument, and I care way more how it stacks up against the later than the former.
Just buy or make a decent cable and rock out. Trying to listen for an improvement in tone as a result of buying a snake oil cable is pointless.
mshilarious, you know way more about the physics of this than I do, so I'm not going to question your far superiour grasp on that.
That said, I disagree with you on this, and I think it's because your knowledge is getting in the way of your objectivity, if that makes any sense. A cable that affects your signal the least possible is maybe a theoretically better cable, in that it does what we expect a cable to do with the least interference, yes.
However, look at the rest of your guitar rig - pickups that don't really provide full frequency input and drop off between 5hz and 8hz or so, depending on model, amplifiers that are designed to clip on both the input and output stage, "tone" controls that cut out certain parts of the signal, and speakers that are nowhere close to full frequency. You've also talked at length about inefficiencies in the ways guitars are wired that cause further problems. Obviously, nowhere else in the signal chain are you really after a component that colors the tone the least - why should a cable be any different? Amps that intentionally distort at low volumes, or pickups that are mostly concentrated below 6khz are all easily more "inefficient" than a lot of guitar cables.
The way I see it, guitarists have been using, and growing up listening to, the sound of very inefficient, non-full-frequency gear for generations now. It's part of the sound of the electric guitar, and that sound is why we all play today. I think it's important to pay attention to the science behind gear too and it can be very useful in debunking bloated marketing claims, but the ultimate question is, "Yes, but how does it SOUND?" If in a double blind test I think a less-efficient cable sounds better in my rig than a more efficient one, then I'm obviously not going to care at all about the science, since the real-world tone is working for me, right?
)Not aimed at you or your post at all but just a stepping off point. ..switching to 'jaded mode (which seems to grow stronger lately..
It seems to me you can find a whole lot of examples in this game, audio, recording, where one as opposed to 'looking for pure accuracy/fidelity', there is no 'true tone' at all. We are rather mixing and matching pieces and sounds, reacting and adjusting, to create –whatever.
From that context I'll ask, what if it (this cable, a mic, the possible examples are endless) -didn't sound the same?
Let's say we step into some (any) given situation, plug in our favorite guitar and amp, mic, whatever. What is the first thing that happens? We adjust, in any number of ways.
Huge variables at play. Move the mic an inch or so, all that.
Hell, I'd be curious, has anyone ever played the same gig, same club', three or four nights in a row and ever have your rig, the stage' sound the same to you each night? I have not.
I would propose that even the human chemistry/perception variable alone swamps many of these 'differences.
Remember, this coming from the context where there is no 'this is the 'real' or this is the true' tone –is where we operate most of the time!
..Third night in, hmm sounds a little scooped', better back the mid back up a bit'.
See where I'm coming from here?
The whole point here is about money, not tone. If one likes a particular tone, it behooves one to obtain that tone in the cheapest way possible, yes? So if somebody tries to sell you an expensive cable, isn't it useful to know why that expensive cable is expensive? Is it because they really did use super-expensive materials that somehow defy the laws of physics? Or could you achieve the same result with a little bit of knowledge and a lot less money?
I do agree that ultimately what you and I need to do is find the cheapest way to get a sound we;re happy with, and some knowledge of how a cable works may help there, to debunk some of the crazier claims some cable makers will use, but at the end of the day, you can't really put together a killer rig just looking at spec sheets - you need to play.
Well it's impossible to play every combination of everything, isn't it? Unless you don't value your time or your money. So we should take a cut out by rejecting stuff we know doesn't make sense.
Celestion does, as well.Take Eminence, for example. How many different guitar speakers do they stock? Thirty or so, I think. They all have subjective tonal descriptions, which is what most guitarists will read . . . but they also all have complete specs, including frequency response and impedance curves and Thiele-Small parameters. So I'm glad they care![]()
^^^^this^^^^I'm with the lieutenant on this one. I grab whichever cable is handiest. When I buy, I look for the cheapest that looks strong enough.
To me, the argument falls into the same category as those supporting sampling rates of 96 or 192 over 44. There may be differences . . . but who cares? The differences (if they exist) are so marginal that they are overwhelmed by other quality factors in the playing or recording signal path.
You also have to understand cable effects as a function of length. Let's say you found that Monster cable groovy. OK, you now know you want a 1.4nF load on your guitar for that groovacious tone. But it's only a 12' cable, so that's fine in your studio but you need a 30' cable for live. So now you need a 50pF/ft cable to get the same load as your Monster shorty. Beware if you buy a 30' Monster though, that would be a much heavier and therefore possibly bad-sounding load.
