taylorguitarman
I finally ran into my first balanced/unbalanced problems. I bought a balanced patchbay to hook all my gear (mostly balanced) and found out that the outputs of my workstation are unbalanced as well and one of my monitors are unbalanced and so is my soundcard interface (arg). So I was initially confused when the levels were so low when I hooked everything up. After a bit more re-reading (and understanding now) how do manage balanced/unbalanced connections for gear? Or do you just make sure everything is one or the other? I'm trying to make the switch to a DAW now that I've quieted my PC down and I've been frustrated trying to get everything to play nice with each other. I'm planning on getting a new soundcard (I need more inputs) so that should help but why does it have to be this confusing?
I've been thinking of getting a Big Knob for my monitoring hookups, will that do balancing/unbalancing successfully to run my CD player, PC, etc? With all those knobs and inputs it looks like it will but I'm not sure.
