N
notbradsohner
Compression Addict
when wiring up insert cables, what do you do with the ground? I assume you can just use balanced cable, split the pos. and neg. to the tip and ring of the TRS end, but what do you do on the two TS ends? Is there special insert cable with seperate grounds to positive and negative?
