Senility must be kicking in, or maybe I just need a different mixer...need help with getting a monitor mix on a Mackie....here's my setup:
DAW using Cakewalk
Delta 66 for audio
SB Live! for MIDI
PS5 monitors
Mackie 1202 VLZ Pro
I've got the mic going into Channel1 XLR, output from the Delta 66 going into 5/6, output from SB Live! going into 7/8. I would like to be able to use EQ, Gain, and FX going to the Delta In but have a separate strip to use EQ, Gain, and FX going to a monitor (headphone) mix. In other words, I want to be able to control how much EQ, Gain, and FX I record with, yet be able to separately control the EQ, Gain, and FX from the mic channel blended in with the input on 5-8. Using the direct out on Channel1 is pre-EQ pre-fader and won't allow EQ or FX control.
I tried the Alt 3/4 and Control Room outs, but haven't found that "right" combination yet. Any ideas?
DAW using Cakewalk
Delta 66 for audio
SB Live! for MIDI
PS5 monitors
Mackie 1202 VLZ Pro
