tubedude
Active member
So far, not much to say as I haven't had a chance to give it a run and put it under pressure.
So far though, no "annoying whine" that a few people have mentioned. I wonder if this isn't a problem amongst other equipment or certain combinations thereof.... grounding issues maybe?
Listening to about 4-5 songs from different bands/projects, I must say that I can hear the difference between the 400F and the Delta 1010. Its a pretty obvious difference. Not a huge difference in my untreated room, but enough to say "ahhhh" The high end is very, ummm, clear and present, if that makes sense to you. Not present in a boosted 12k kind of way, but present in that things are more clear, open, "clean". The music seems to be more outside of the speakers now. More 3D-ish.
The drivers loaded up in just a few seconds flat and within 1 minute I was passing audio. No problems or hangups (aside from having to install windows SP1 to get the drivers to install, but I guess I should have done that 3 years ago.)
The box feels sturdy enough, looks nice, and is surprising shallow. Its probably like 4 inches back into the rack. Come to think of it, I guess the Delta is about the same.
Turn off your monitors before you turn off the 400F though unless you want to buy new tweets.
More to come when I really get huffing with it in the next day or two. Anyone else had thier hands on one yet? Craig Anderton is doing a very good review over at his forum too.
