C
		calvinist216
Hello All!!
I've searched through the threads as much as I could trying to find someone with a similar problem, but no one seems to have the exact same issue...
I am recording through an M-Audio pre into Cubase SX on a Mac G4. I am also running Cubase LE with a Tascam interface and/or a Zoom USB guitar pedal into a custom PC.
No Matter which set up I use, I am experiencing little occasional pops/cracks on the audio tracks. They are VERY intermittent...but they are enough to ruin an otherwise solid take.
I Have set the Buffer levels as high as they will go on both versions of Cubase on each computer. The only common factor in every audio crack/pop is that I am using a version of Cubase. So I have 2 questions:
1.) Is there something I could be doing to cause the little cracks, since it seems to be happening no matter what computer/interface combo I use...??
2.) Since they are not major pops all over the place, is there a way to just filter them out with a quick editor tool in Cubase?? Is there a trick to quickly fixing these little nuances without having to re take and re take until its right AND sans cracks & pops??
These may seem like simple problems, but I am new to hard disk recording, having used Otari 8 tracks and ADATs all my life. Waveform editing is greek to me.
Thanks!
Thanks!
