jingleheimer said:
I have been using my windows computer for some time for recording and i was wondering why I was using it. (And i know that primarily it is up to user preferance but technically which is the better system?) Should i be using a windows or should i be using a mac? I have heard that macs are easier to recover data if something goes wrong and that they are a stabler system all around but is this true and if i should be using a mac what recording programs would you suggest? Thank you very much to everyone -Jingleheimer-
My bias up front. I've been a Mac user for ages, and professionally, I write documentation on how to write drivers for Mac OS X. This both makes me very knowledgeable on the subject, and very biased. Several grains of salt. As always, all opinions expressed are mine and mine alone.
As a general rule, the more people you have with their fingers in the deepest parts of the OS, the less stable the system will be. That's where Mac OS X really shines, IMHO.
I haven't done any Windows driver development, but here are my thoughts based on reading through some of their APIs a while back:
- Mac OS X has a modern, highly unified driver architecture that was designed for things like audio from the beginning; Windows has a hodge-podge of different driver APIs.
- Mac OS X tends to move a lot more drivers into user space (out of the kernel) than Windows, which means less code running in the guts of the system to begin with.
- Mac OS X has built-in drivers for a lot of common hardware; on Windows, hardware manufacturers generally roll their own.
- With Mac OS X, the driver model was designed to maximize reusability, so drivers tend to contain less custom code than their Windows counterparts..
- Because of tight OS/hardware integration, with Mac OS X, you're less likely to start building your system on shifting sands.
It is perfectly possible to set up a stable Windows system for use as a DAW. It just requires careful selection of components.
This is, of course, entirely my opinion, and mine alone. All views expressed do not necessarily represent the views of my employer, yada, yada, yada. In fact, they may not even be my opinions. I may not even be myself. Your mileage may vary. Some restrictions and exclusions may apply. See store for details. Not all drivers may qualify.
