somegeezer
4 Gazillion Rhodium User
I just opened up the BIOS screen (don't worry. I didn't change anything.. just snooped around)
I saw that it did have the correct processor type and speed listed and the correct RAM listed.
Does that not necessarily mean that it is set-up for those or is it just a matter of the computer recognizing those parts?
And I was messing around with Cubase last night and saw that the bar in the little ASIO strain window by the transport control was unusually high when I had the tascam set to lowest latency (as I have always done)...Tascam problem perhaps?
That's just it recognising the parts. The settings as such can be a range of numbers. If you can find out exactly what model your RAM is, you should easily be able to Google what the recommended voltage and timings are for it. Like I know my RAM is best at 9-9-9-24 at 1.65v. Surprisingly pushed right up to its limit too. I tried upping it just a little bit and it couldn't handle it. So RAM is generally best at stock. Your CPU will work within a range though. They are purposefully set lower than needed by default. Unless you're overclocking, you don't need to worry a whole lot about getting the most out of it. But differences in frequency and/or clock cycles and/or voltage could make a difference beween working great and getting BSOD.
Right now, I'd just do what's already been said before messing around with that stuff though. Perhaps if you haven't already, just try a good old defrag? See if that helps any. Complete reinstall of OS and such should help if that doesn't though. I certainly wouldn't be installing stuff like macafee again though. Stick to Microsoft Security Essentials if you're using that machine for internet too. It works without disrupting everything and updates through your windows updates.
