SRR
Use the arrow keys on your keyboard to move the little slider one notch at a time.
punkin said:The switch on the mic is an attenuator. 0 means no reduction in signal output of the microphone, -10 means 10 dB of signal output reduction (attenuation) and -20 means 20 dB of reduction. You would use this when recording loud audio sources which might over drive the input to the mic pre.
The plus (+20) switch on the Tampa is similar but backwards. When turned to +20 increases the gain of the microphone signal and you can't get enough signal to your recording card. This is usually done when you're using a mic with low output characteristics or, if you're recording a very quiet signal. It would be a goofy thing to have the mic switch turned to -20 and the Tampa set to +20 (get it?).
The impedance setting is to match the mic pre input impedance with the mic output. I don't know anything about your mic. If you bought your mic new, the owner's manual will tell you. There's no chance of any harm to the gear by having a mis-match but it could impart an audio quality/tonality difference.
The meters...the input meter shows how much signal is coming from the mic going into the mic preamplifier. Too much and it over drives the input of the amp and sounds crappy. 100% is probably too high...occasional peaks close to 100% is ok...good actually. The output meter shows how much signal is going to your computer recording card. Again 100% is not good. (so to recap, there's a gazinta gauge and a goezoutta gauge) In stead of focusing on the output meter of the Tampa, I would look at the M-Audio Delta card input meters for that channel. Again, getting close to 100% is ok...pegging the meter is bad. Too low, and you don't make the most of the available recording band width and during playback, you've got to turn the volume control way up.
You keep making reference to listening on the headphones...is this during record or playback (after recording)? I would focus on the quality of the actual recording. You'll make much better and faster progress.
You're on a roll...get in there and play with the gear!
SRR said:Use the arrow keys on your keyboard to move the little slider one notch at a time.
Load impedance: >1000 Ohm.
So with those specs, what should I have the dial switched to?
2400, 1200, 600, 300
SRR said:Your problems are probably in your recording program, make sure on the track you want to record on to, that you select inputs 3/4 for your drum machine. How you do that varies by program to program.
Also you will probably want in the patchbay/router of the m-audio control panel to have 1/2 be wavout not monitor mixer. MM will take everything from your recording program and your other hardware inputs and mix it all together. Where here you just want to be listening to what your recording program is doing.
Also is there any reason you can't EQ the drums in your recording program rather then the mixer? Almost any EQ plugin is probably gonna sound better then the EQ on your mixer.
We are almost there....![]()
punkin said:OK...so here's the deal...we've spent a bunch of time heppin' you. Post an audio clip "K"? The fruits of labor...let's hear it...seriously.
BTW...welcome to the sickness![]()
