Y
YuvalAS
Hey,
About 4-5 months ago I posted here the following thread: https://homerecording.com/bbs/equipment-forums/microphones/dilemma-mic-should-i-get-329471/2/
Finally I changed direction at all, and ended up buying a brand new matched pair of the M-Audio Pulsar II (as I got this pair for $135 when it usually sells for $300 with msrp $400...)
I couldn't save money on the shipment, and paid for air-shipping instead the standard overseas shipments (so I've already received them after 7 days, not 40..)
So I'm generally satisfied with how the microphones pick up the sound of my guitar, but have just one thing weird with them..
I used them with the M-Audio Fast Track Pro A/I and somehow I don't hear anything until I boost up the gain to the max (which is over 40dB I think).
The preamps on my A/I add noise to the signal even when no cable is connected to the input. So my problem is that I can't use the mics at a lower gain, and with a higher gain I hear noise...
I assume you're gonna suggest buying a dedicated preamp as the output impedance of the Pulsar is very low, and a good preamp will be able to give gain along with clarity..
But as you know, I'm 17 y/o boy so I have a very low budget and I buy anything in steps..
So I know that I'll be looking forward to buy a good preamp, but not now..
Now I need any temporary suggestion to cancel the noises without affecting the sound quality, or getting a soung out of the mics at a lower gain... [btw I made sure that the -10dB pad is off, as well as the 80Hz high-pass]
Also, can you give me some good suggestions on the mics positions? M-Audio only suggests the X-Y and ORTF positions..
I "played" with positioning and thought that what sounds best was: one mic in front of the 12nd-14th fret at about 6 inches away of the guitar, and second mic that comes from a 2 inches distance from the first mic positioned to the right side of the guitar's body (where the guitar mostly produce bass - even more right relative to the soundhole...
I'd be happy to hear about more mics positions for acoustic guitar. and also for a cajon (I put in the ORTF position against the front of the cajon, from about 8 inches far), at a very low height (about 5 inches from the floor).
So we have:
1. preamp noise at high gain problem, and
2. mics positions for acoustic guitar and cajon...
Thank you so much in advance, and happy new year
Yuval
So we have:
Yuval
