Bigus Dickus
Here's the short version (like I ever make anything short)...
I'm tracking into the Delta Dio 2496 in 24 bit 88.2 kHz using a dbx A/D converter.
Upon the recommendation of everyone here (and by my own logic), the Delta is set in the control panel to sync to the incoming S/PDIF signal for its sampling frequency.
When setup like this, tracking is fine. However, playback is, um... very bizarre. It's like it's playing at 1/20th the speed or something.
So, my first thought was that, having the control panel set not to use the Delta's own internal crystal, but an outside signal, that it was getting "confused" as to what sampling rate to use.
Sure enough, change the sampling rate from sync to S/PDIF to use internal crystal (at the sampling rate the tracks were created using) and everything sounds normal.
Again, playing an .mp3 file, if the Delta is set to sync to an incoming signal, it plays it in slow motion. Using internal crystal, it plays fine (at any sampling rate, mind you, I guess since it isn't receiving a "hardware locked" sampling rate like Cubase is sending it).
Well, that was short, no? This causes great concern for me. Apart from the profound nuisance of having to change the setting in the control panel every time between tracking and playback, I'm also worried that it might cause a problem with monitoring (haven't gotten that far yet).
Any suggestions? This is with the .0027 Delta drivers. Is there any way to leave it synced to internal crystal, except have Cubase, or whatever I decide on using, automatically switch the sync to external?
