Low latency monitoring
  • Thread starter Thread starter Hasse
H
Hasse
Hi
Hope som a you can help me with a little problem I have. I own a Digirack 003+ when I record (Acoustic Guitar) I use Low latency monitoring to avoid/minimize latency. I then set up an Aux track with hall reverb and route it by bus to the Audio track, but the reverb is muted. Is there any way I can record with Low Latency Monitoring and still hear the reverb when recording?
Best regards
HaK
If you are using a "send" from the recording track to an aux track running a reverb plug-in, make the "send" pre-fader. That should allow you to hear the verb even though the recording track is muted. I do this with the projectMix I/O so I am making the assumption that the 003 and LE will work the same way.
