Low Frequency Oscillation
  • Thread starter Thread starter Linchpin
Linchpin-
What you want is a filter that you can change the cutoff with an LFO--probably a Low-Pass filter, or if you want a wah-wah sound, then you want a bandpass filter.
Look at my post above, I'm pretty sure these are the types of boxes you are looking for...otherwise, you need to do it with a synth, or a filter plugin- try the NorthPole db filter, it's free and excellent.
Regebro is offering advice on exactly what you described- plus, a Boss chorus guitar pedal isn't the most versatile in determining what a chorus can do in the recording world.
I think someone is selling a electrix filter queen in the classifieds section...check it out.
Amen
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Low Frequency Oscillation
Linchpin said:
A box with delay that I can set 1-30 milliseconds, LFO i can dial in at 0.x hz, and maybe a sine/triangle/saw switch. Essentially just an LFO vst plug-in but in the form of hardware. You would think gear like this would be standard issue shit.
Well, choruses that you can dial in the exact settings in Hz and ms are pretty unusual. Mostly you just set them by ear to what sounds good. I would expect a lot of the really high-end gear has settings like this, but I don't know for sure, since my budget doesn't allow for it. :)
On a side note, you sure are concerned with how you make someone "look" on an internet forum. That, to me, speaks volumes.
Oh, interesting (I mean that). What does it say? That I'm not usually trying to make people look stupid but recognize that I sometimes to anyway, says what, exactly?
I'll let you go ahead and throw the last terd.
No thanks. I haven't trown any turds in this thread at all so far, and I see no reason to start now.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Low Frequency Oscillation
Well acually you did just by posting it.....................................
I do agree that posting a turd and throwing it is the same on an electronic forum, yes. :D
Was that your point? ;)
Or are you trying to say that I throw turds when I say that I'm not throwing turds? Could you then explain the logic behind that, because I don't get it.
