Low end problems
  • Thread starter Thread starter mentalattica
mentalattica
mentalattica
Just a Home Recorder
Hello all,
I wanted to get some input on possibly something I'm doing wrong here. I've been going back and remixing all of my songs as of recent but I'm having a huge problem with the low end on quite a few songs.
My mixes translate well on desktop speakers and home stereo's but in cars I've heard so many different things. One of my cars has a stock radio and speakers, the mixes sound a little heavy in the low end. My other car has a custom sound system with a set of 12" subs, and it's screaming waaaay too much low end at me (I usually listen to everything with the same bass and trebble settings bass is at -4 and trebble at +6 on a scale of 1-10).
So I get back in my studio and bump the bass down a bit by either turning the kick drums or basseline down a few db, or eq'ing individual tracks. Now my monitors (KRK RP8 & BX5's) are telling me not enough low end, but I double check on other sources to be sure. I go back through the process of home stereo, desktop speakers where they still sound OK at best but lacking
in the bass dept. you can barely hear the kick but you know it's there.
Then, out to the cars and they sound good in the "stock" stereo but in my custom stereo they sound pretty damn bad and are still saying too much low end on a few mixes. I can't get them to sound even OK on all playback sources I use, they'll sound good on one, OK on another and terrible on another.
I've had people tell me my mixes sound really good, but I just don't hear it (Nor would most people on this board from just reading a lot of what you guys have to say). If I can't say "these mixes sound really good" to myself and believe it, others opinions don't matter as much. Over critical??
Could it be something I'm doing wrong? (obviously)
But any idea's without actually hearing the mixes in question?
alright this is gunna sound weird but it makes sense at least to me
people have said ive made good mixes too, but it always seems like everyones better at it. i think it IS that we are overcritical of ourselves about everything in life, it has to do with not being satisfied no matter what we have. like if you and one person own the same item it always seems like theirs is better etc im not sure if you can connect with what im saying because i dont know how to word it correctly
anyway
ive heard krks lack bass and the bx5s as well
get a subwoofer monitor?
I can definitely relate to what your saying. Possibly being too critical can cause me to "miss out" on my best possible mix because the best possible is never enough so things always get altered.
do a search around here about bass traps.....there have been TONS and TONS of posts (especially recently) regarding this issue. This will probably help a ton allowing you to hear truer bass response at the mix position.
I forgot to mention my room is infact treated with auralex 2" foam on the back and both sides of the mixing position along with a cloud above the mixing position as well as in front of the mixing position (behind monitors). Also 703 OC fiberglass bass traps in 3 of 4 corners. However it is a small square room (bedroom)probably somewhere between 10X10 and 12x12 with a 10 foot ceiling.
this is also the drawback of a lot of music that isn't professionally mastered
