"..Hey umm.. Aretha, can you back way off there please? I know it'll sound like like ass..
but you're distorting here.. Thanks."
Dumb question but to do this, I would need 2 mics, right?
I usually record one track at a time.
Ok, may I suggest- before going off into 'dual level setups you have job one to finish.
This would be to spend some time –before the next 'tracking, to play with your set up.
There's about three places where you can overload;
At the mic- apparently the 2020 doesn't have a pad switch. That drops a
sensitive mic's level for when it's used up close on very loud sources. Instead they set up the 2020 to take 144! without a pad, so unless you're screaming right up on it, this likely not the problem.
At the interface/mic input- Turn it all the way down, set all the other controls in your software to 'zero/'nominal -no boost, no cut, no plugins no add-ons'.
At the conversion to digital.
Record something of 'normal volume ('sing test into the mic is handy way to do this) then,
mic input still at minimum, try higher volumes, until you see it max out –see red' on the meters, hear distortion on play back, clip' flat topped waves whatever.
With all the software controls (except the one for mic input gain) are at zero', your meters will show your recorded
after conversion level.
If the test shows playback below max on the meters, but is distorted, the overload was at the mic input, or at the converter.
The drag with these combo analog/digital/software controlled thingies is it's harder to separate the two.
It is possible (and not uncommon) that on loud sources a hot mic can overload the mic input even at 'minimum gain'. (..and 'minimum is often +10 or 15 of gain you don't even need or want!)
Often for loud things, (
maybe for a loud voice) you may need one of these in that case-
http://pro-audio.musiciansfriend.co...e-Attenuator?sku=275064&src=3WWRWXYB&ZYXSEM=0
Passes phantom power, manages input level to the mic pre.
Or.. use a less sensitive mic, like a dynamic. Also, with a dynamic you get to eliminate 'mic distortion from the questions.
If fact you should do the learning experiments with a dynamic as well.
'Cause all this is going to come up again first time you put a mic on a guitar amp or whatever.
In the end you will a) pick the mic for the one sounds best for what you're doing, b) place the mic where it sounds best, and c) dial in the gains how and where they're needed.
That's the plan.
