H
HomeNoiseRecord
Just to chime in, a little late here...
120 watt guitar amps exist for a very different reason than 5 watt amps. The point of a 5 watt amp, at least today, is to allow you to overdrive the power amp at a reasonable volume, and to give you poweramp distortion. This is great for bluesy and blues/rock tones - SRV, Led Zep, etc - where you're not using much preamp gain, and want the poweramp to distort and saturate into this nice, spongy, touch-sensitive, thick, round guitar sound.
The point of 120 watt guitar amps is the complete opposite - you want them NOT to overdrive the power section, at gigging volumes. Generally, high wattage amps are also either designed to stay crystal clean at any level, or are mated with high gain preamps, so you can get a good preamp distortion sound, and then send it through a poweramp without overdriving it further. This is pretty useful for metal, where aggressive, crunchy distortion is part of the sound, but you also want to preserve low end clarity. A tube poweramp typically will start to distort on the low end first, so by getting the bulk of your distortion from the preamp and then at most adding a bit of natural tube compression from the power amp, you still preserve a lot of low end punch and impact.
It's just two diffrent ways of getting a distorted sound, distorting the preamp or distorting the poweramp. They're both great sounds, but for different reasons and are best in different applications. You're not going to nail the Nevermore sound out of a Fender Champ (at least not without a couple good distortion pedals and keeping an eye on your output knob so you don't saturate the power section), but you're also not going to get the Led Zep I sound out of a Dual Rectifier (at least, not without turning it up to absolutely stupid volumes).
Good post from this man.
HNR
now i think a god exists! i'll choose dzeus or apolo. still choosing
