jeancoltrane
so i picked up an old battery powered mayfair 157 rtr, its a pretty cool machine thats runs at 7ips but has some wow & flutter issues. at first i thought it was the belts/pinch roller but then i realized its not packing tape correctly in either rewind or play. if i pre wind the tape on my teac it seems to help quite a bit, but it still packs loosely on the takeup reel while recording or in play mode, so even if the supply reel is packed tightly its probably still slipping via the takeup reel.
i also noticed when you hit 'stop' it doesnt seem to have any breaks, you have to manually stop the reel with your hand. i dont know if those issues are connected, but is there generally some type of brake or tension mechanism that may be worn out causing loose tape packing and thus wow & flutter?
thanks
thanks
